Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
Pry the plastic bezel from the back plate using a plastic opening tool.
Remove the plastic bezel entirely and set it aside.
Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
Use the spudger to separate the screen from the back case.
Hold the screen in one hand and tilt the back case away from you.
The screen is connected to the back case by two leads.
Remove the two leads from the screen. They will stay connected to the computer.
Remove the screen carefully.
9 outras pessoas executaram este guia.
