Ir para o conteúdo principal
Dell Inspiron E1705 Upper Case and Screen Replacement
O que você precisa
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: passo 1, imagem 1 %32
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 2, imagem 1 %32 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 2, imagem 2 %32
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 3, imagem 1 %32 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 3, imagem 2 %32
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 4, imagem 1 %32 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 4, imagem 2 %32
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 5, imagem 2 %32
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
Conclusão
9 outras pessoas executaram este guia.
Evan Fairchild
Membro desde: 10/05/10
613 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 7,014
