Ir para o conteúdo principal
Dell Inspiron E1705 RAM Replacement
O que você precisa
  1. Dell Inspiron E1705 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
    Introduction: Parts: Need to add the Fan Part Numbers
    Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
    John Frazier - Responder
  2. Dell Inspiron E1705 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron E1705 RAM Replacement: passo 2, imagem 2 %32
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 RAM Replacement, RAM: passo 3, imagem 1 %32 Dell Inspiron E1705 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Turn the computer over, screen closed, so that the underside is showing
    • Locate the two screws as shown and remove them.
    • Use a small phillips head screwdriver
  4. Dell Inspiron E1705 RAM Replacement: passo 4, imagem 1 %32 Dell Inspiron E1705 RAM Replacement: passo 4, imagem 2 %32 Dell Inspiron E1705 RAM Replacement: passo 4, imagem 3 %32
    • Remove plastic cover carefully
    • There will be two RAM sticks as shown
    • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
  5. Dell Inspiron E1705 RAM Replacement: passo 5, imagem 1 %32
    • Carefully remove old/damaged RAM sticks and replace with new ones.
Conclusão
5 outras pessoas executaram este guia.
Evan Fairchild
Membro desde: 10/05/10
613 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
Membros da 4
Autoria de 11 guias
Um comentário
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 8,145
