Ir para o conteúdo principal
Dell Inspiron E1705 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron E1705 Optical Drive Replacement: passo 2, imagem 2 %32
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron E1705 Optical Drive Replacement: passo 4, imagem 2 %32
    • Use the screwdriver to gently push the optical drive out
Conclusão
3 outras pessoas executaram este guia.
Evan Fairchild
Membro desde: 10/05/10
613 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 3,926
