Peças
Não são necessárias peças.
  1. Make sure that the computer is turned off and is disconnected from external power source.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. While holding the switch in the open position, lift out the battery.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
    • Remove the 12 Phillips #1 screws from the edges of the lower case.
    • You may also need to remove the central screw next to the lock icon.
    • Turn the computer back over and tilt the screen open.
    • Use the plastic opening tool to carefully pry the panel out as shown in the pictures
    • Remove the plastic panel carefully.
    • Use the small Phillips head screwdriver to remove the screws circled in red.
    • Gently lift the keyboard up and rest it just below the screen as shown in the picture.
    • The keyboard will still be connected to the motherboard.
    • Before removing the keyboard completely, use the plastic opening tool to gently lift the clamp connecting the keyboard to the motherboard.
    • Once the keyboard has been disconnected, remove the keyboard completely.
    • Using a Phillips head screwdriver, remove the screws shown in the image. They all have the letter "P" next to them.
    • Carefully unplug the connections shown.
    • Don't forget the display cable. It is slightly to the right of the Dell logo at the top.
    • Also, the wireless cables on the right side may prevent moving the upper case out of the way.
    • Once the screws have been removed and the connections unplugged, use the plastic opening tool to gently separate the panel from the lower case.
    • Remove the plastic case by gently bending back towards the screen. You can bend the screen all the way back if that helps.
    • For the motherboard the optical drive will be removed already. However for the lower case it is not necessary that it be taken out.
    • If you are having trouble removing the upper plastic case (and LCD) from the lower case, there may still be a wire connected to the Wi-Fi adapter. Turn the laptop over, open the Wi-Fi module access panel and remove the + and - leads for the Wi-Fi antenna.
    • Unscrew the 4 screws shown in the picture.
    • Screws will not come out all the way.
    • Remove the heat sync gently
    • The right heat sync is connected to the videocard. To remove the heat sync requires also removing the videocard.
    • Remove the 4 screws indicated in the first picture
    • Screws will not totally come out.
    • Gently lift up the videocard and heat sync from the motherboard.
Conclusão
2 outras pessoas concluíram este guia.
Malik Shahbal
429 reputação
5 Guides authored
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membros
11 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Todo: 3,956
