Pular para o conteúdo principal
Introdução
This guide is very important for other guides, as the battery must be removed before dealing with electronic connections within the computers encasement.
  1. Make sure that the computer is turned off and is disconnected from external power source.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Conclusão
To replace your battery, follow these instructions in reverse order.
4 outras pessoas concluíram este guia.
Malik Shahbal
Membro desde: 05-10-2010
435 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membros
11 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Todo: 3,876
