Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Dell Inspiron E1505 Optical Drive Replacement
O que você precisa
  1. Dell Inspiron E1505 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Optical Drive Replacement: passo 2, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Optical Drive Replacement: passo 3, imagem 1 %32
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Optical Drive Replacement: passo 4, imagem 1 %32
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
  5. Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: passo 5, imagem 1 %32 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: passo 5, imagem 2 %32 Dell Inspiron E1505 Optical Drive Replacement, Optical Drive: passo 5, imagem 3 %32
    • Remove the back panel: Use the screwdriver to remove the screws on the back panel.
    • Lift the back panel off the laptop to expose the interior of the laptop.
    • Locate the hard drive.
  6. Dell Inspiron E1505 Optical Drive Replacement: passo 6, imagem 1 %32
    • Remove the current hard drive.
    • Look at the model number and order the replacement if needed.
    • Insert the new hard drive in.
Conclusão
Anthony Toscano
Membro desde: 10/20/16
323 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-7, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
Membros da 3
Autoria de 4 guias
2 comentários
@oldturkey03 This guide is showing how to remove the ODD, not the HDD. I was wondering if I should change it. The guide is also incorrect. Only one screw is necessary to remove the ODD. I suppose I should make another and archive this...
George A. - Responder
@pccheese it's a student guide so leave it alone. Do not archive anything on this. Go ahead and create your guide and then post that as an alternative. I would give the composer of this guide the courtesy and kindly let them know.
oldturkey03 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 701
