Ir para o conteúdo principal
Dell Inspiron E1405 Heat Sink Replacement
O que você precisa
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Inspiron E1405 Heat Sink Replacement: passo 2, imagem 2 %32 Dell Inspiron E1405 Heat Sink Replacement: passo 2, imagem 3 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: passo 3, imagem 1 %32 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: passo 3, imagem 2 %32 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: passo 3, imagem 3 %32
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: passo 4, imagem 1 %32 Dell Inspiron E1405 Heat Sink Replacement: passo 4, imagem 2 %32 Dell Inspiron E1405 Heat Sink Replacement: passo 4, imagem 3 %32
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
Conclusão
Equipe
Texas Tech, Team S8-G3, Bennett Spring 2017 Membro de Texas Tech, Team S8-G3, Bennett Spring 2017
TTU-BENNETT-S17S8G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 207
