Ir para o conteúdo principal
Dell Inspiron B130 RAM and Wireless Replacement
O que você precisa
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, imagem 3 %32
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: passo 2, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 2, imagem 2 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 2, imagem 3 %32
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: passo 3, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 3, imagem 2 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 3, imagem 3 %32
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: passo 4, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: passo 4, imagem 2 %32
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: passo 5, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 5, imagem 2 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 5, imagem 3 %32
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: passo 6, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 6, imagem 2 %32
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: passo 7, imagem 1 %32 Dell Inspiron B130 RAM and Wireless Replacement: passo 7, imagem 2 %32
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Conclusão
Uma outra pessoa concluiu este guia.
Patrick McNeil
Membro desde: 10/19/16
937 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 262
