Ir para o conteúdo principal
Dell Inspiron B130 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron B130 Hard Drive Replacement: passo 2, imagem 2 %32 Dell Inspiron B130 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron B130 Hard Drive Replacement: passo 3, imagem 2 %32 Dell Inspiron B130 Hard Drive Replacement: passo 3, imagem 3 %32
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
Conclusão
Patrick McNeil
Membro desde: 10/19/16
937 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 622
