Ir para o conteúdo principal
Dell Inspiron 9300 Trackpad Replacement
O que você precisa
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the twelve 6mm Phillips case screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: passo 3, imagem 1 %32
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 2 %32 Dell Inspiron 9300 Trackpad Replacement: passo 4, imagem 3 %32
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard
  5. Dell Inspiron 9300 Trackpad Replacement: passo 5, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 5, imagem 2 %32
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: passo 6, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 6, imagem 2 %32
    • Remove the seven 6mm Phillips scres holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger
  7. Dell Inspiron 9300 Trackpad Replacement: passo 7, imagem 1 %32 Dell Inspiron 9300 Trackpad Replacement: passo 7, imagem 2 %32
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger
    • Remove the trackpad ribbon cable from the motherboard using a spudger
  8. Dell Inspiron 9300 Trackpad Replacement: passo 8, imagem 1 %32
    • Pull up and away on the uppercase to remove.
Conclusão
Steven Faulkner
Membro desde: 09/26/16
214 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro de USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 183
