Ir para o conteúdo principal
Dell Inspiron 9300 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
    • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
  2. Dell Inspiron 9300 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the two 5mm Phillips screws holding the keyboard in place.
  3. Dell Inspiron 9300 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the keyboard away from the laptop.
    • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
  4. Dell Inspiron 9300 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 9300 Keyboard Replacement: passo 4, imagem 2 %32
    • Gently pull up on the blue tab to disconnect the keyboard.
    • Pull the keyboard up and away to safely remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Ady Alhamra
Membro desde: 09/26/16
149 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro de USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 515
