Ir para o conteúdo principal
Dell Inspiron 9100 Optical Drive/Accessory Device Replacement
O que você precisa
  1. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: passo 1, imagem 3 %32
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: passo 2, imagem 1 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: passo 2, imagem 2 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: passo 2, imagem 3 %32
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: passo 3, imagem 1 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: passo 3, imagem 2 %32 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: passo 3, imagem 3 %32
    • Press the tab on the outside face of the optical drive to release a handle.
    • Pull the handle to eject the optical drive unit from the slot, and slide it out.
Conclusão
charlierefvem
Membro desde: 01/11/11
854 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-2, Forte Winter 2011 Membro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membros
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 2,266
