Ir para o conteúdo principal
Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
O que você precisa
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: passo 1, imagem 3 %32
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 2, imagem 2 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 2, imagem 3 %32
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: passo 3, imagem 1 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: passo 3, imagem 2 %32
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 4, imagem 1 %32
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 5, imagem 1 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 5, imagem 2 %32 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: passo 5, imagem 3 %32
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusão
Uma outra pessoa concluiu este guia.
charlierefvem
Membro desde: 01/11/11
854 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-2, Forte Winter 2011 Membro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 4,267
