Introdução
This guide will teach you how to remove the buttons below the track pad from the laptop device.
Ferramentas
Peças
Nenhum componente especificado.
Locate the release tabs located on either side of the battery, on the bottom of the laptop.
Push the release tabs toward the center of the device.
Remove the battery.
Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
Uma outra pessoa concluiu este guia.
