Ir para o conteúdo principal
Dell Inspiron 910 Touchpad Buttons Replacement
O que você precisa
  1. Dell Inspiron 910 Touchpad Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Touchpad Buttons Replacement, Keyboard: passo 2, imagem 1 %32
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Touchpad Buttons Replacement: passo 3, imagem 1 %32
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Touchpad Buttons Replacement, Touchpad Buttons: passo 4, imagem 1 %32
    • Remove the seven Phillips #00 screws that hold the metal component to the frame
    • Detach the two ribbon cables on either side of the silver panel
    • Be careful to not tear the ribbon cables hidden behind the panel
    • Gently lift the silver panel from the laptop using the plastic opening tool
    • Set the laptop aside
    • depending on your model, there could still be some hidden screws on the bottom of the case of the mini that hold the palm-rest in place
  5. Dell Inspiron 910 Touchpad Buttons Replacement: passo 5, imagem 1 %32
    • Flip the silver panel over
    • Remove the four screws that connect the buttons to the panel using the Phillips #00 Screwdriver
  6. Dell Inspiron 910 Touchpad Buttons Replacement: passo 6, imagem 1 %32
    • Remove the covers from the panel
    • Remove the buttons from the panel
    • Release the mouse button by flipping the center connector tab up
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Beekman
Membro desde: 04/05/12
144 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-10, Forte Spring 2012 Membro de Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,197
