Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Dell Inspiron 910 Speakers Replacement
O que você precisa
  1. Dell Inspiron 910 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speakers Replacement, Keyboard: passo 2, imagem 1 %32
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speakers Replacement: passo 3, imagem 1 %32
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speakers Replacement, Speakers: passo 4, imagem 1 %32
    • After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speakers Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speakers Replacement: passo 6, imagem 1 %32
    • There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • NOTE: Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speakers Replacement: passo 7, imagem 1 %32
    • There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
Conclusão
3 outras pessoas executaram este guia.
Kyle Beekman
Membro desde: 04/05/12
144 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-10, Forte Spring 2012 Membro de Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,522
