O que você precisa
Remove the two screws that secure the solid-state drive.
Lift the solid-state drive out of its system board connector.
Insert the solid-state drive into the slot at a 45-degree angle.
Press the solid-state drive down and replace the two screws that secure the drive.
Replace the module cover
Slide the battery into the battery bay, until it clicks into place and slide the battery-lock latch towards the lock position.
Make sure to replace all screws and ensure that there are no stray bolts.
Uma outra pessoa concluiu este guia.
