Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide it will be demonstrated how to replace the memory on a Dell Inspiron 910 laptop.
O que você precisa
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
4 outras pessoas executaram este guia.
