Introdução
In this guide it will be demonstrated how to replace the memory on a Dell Inspiron 910 laptop.
Ferramentas
Peças
Nenhum componente especificado.
Locate the release tabs located on either side of the battery, on the bottom of the laptop.
Push the release tabs toward the center of the device.
Remove the battery.
Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
4 outras pessoas concluíram este guia.
