Ir para o conteúdo principal
Dell Inspiron 8600 Video Card Replacement
O que você precisa
  1. Dell Inspiron 8600 Video Card Replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: passo 2, imagem 1 %32 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: passo 2, imagem 2 %32 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: passo 2, imagem 3 %32
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Video Card Replacement: passo 3, imagem 1 %32
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Video Card Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 8600 Video Card Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron 8600 Video Card Replacement, Keyboard: passo 4, imagem 3 %32
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Video Card Replacement, Video Card: passo 5, imagem 1 %32 Dell Inspiron 8600 Video Card Replacement, Video Card: passo 5, imagem 2 %32 Dell Inspiron 8600 Video Card Replacement, Video Card: passo 5, imagem 3 %32
    • After removing the keyboard, locate and remove the labeled screws.
    • Gently lift the Video Card unit for replacing.
Conclusão
3 outras pessoas executaram este guia.
Brian Murphy
Membro desde: 04/13/11
368 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 24
Duração total: 7,100
