Ir para o conteúdo principal
Dell Inspiron 8600 Power Button Replacement
O que você precisa
  1. Dell Inspiron 8600 Power Button Replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, imagem 1 %32 Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, imagem 2 %32 Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, imagem 3 %32
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: passo 3, imagem 1 %32
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
Conclusão
3 outras pessoas executaram este guia.
Brian Murphy
Membro desde: 04/13/11
368 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 18
Duração total: 4,167
