Ir para o conteúdo principal
Dell Inspiron 8600 LCD Replacement
O que você precisa
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 2 %32 Dell Inspiron 8600 LCD Replacement, Hinge Cover: passo 1, imagem 3 %32
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: passo 2, imagem 1 %32
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: passo 3, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, Display Module: passo 3, imagem 2 %32
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: passo 4, imagem 1 %32
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: passo 5, imagem 1 %32 Dell Inspiron 8600 LCD Replacement: passo 5, imagem 2 %32
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: passo 6, imagem 1 %32
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 1 %32 Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 2 %32 Dell Inspiron 8600 LCD Replacement, LCD: passo 7, imagem 3 %32
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: passo 8, imagem 1 %32
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: passo 9, imagem 1 %32
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: passo 10, imagem 1 %32
    • Remove the broken LCD unit, and replace with new unit.
Conclusão
Perry
Membro desde: 04/12/11
251 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membros
Autoria de 16 guias
Um comentário
which controller board do i have to use for this model ?
bcdoor - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 4,704
