Ir para o conteúdo principal
Dell Inspiron 8600 Hinge Cover Replacement
O que você precisa
  1. Dell Inspiron 8600 Hinge Cover Replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, imagem 1 %32 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, imagem 2 %32 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, imagem 3 %32
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Hinge Cover Replacement: passo 3, imagem 1 %32
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
Conclusão
Uma outra pessoa concluiu este guia.
John Nesthus
Membro desde: 04/13/11
186 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 3,531
