Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
We will show you how to remove both the upper and lower cases of the laptop. You will then remove the old strip then replace the hinge cover. And finally re-attach the upper and lower cases.
Peças
Nenhum componente especificado.
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off. Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover. Be careful of wire attached to underside of the hinge cover.
    • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
    • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
    • Be careful of wire attached to underside of the hinge cover.
  4. Pull the small black tab on the right hand side of the laptop.
    • Pull the small black tab on the right hand side of the laptop.
    • The hinge cover has now been removed.
Conclusão
Uma outra pessoa concluiu este guia.
John Nesthus
Membro desde: 13-04-2011
186 Reputação
6 Guias de autoria
equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membros
16 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 3,303
