Introdução
The display module is an essential piece of the Dell Inspiron 8600. If it malfunctions or the screen breaks, its removal from the base may be needed for inspection or/and replacement purposes.
Follow this guide to remove the display module of your Dell Inspiron 8600.
O que você precisa
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
