Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will show you how to remove the CD-Rom Drive and replace it with a properly functioning one.
Peças
Nenhum componente especificado.
  1. Remove the battery from the bottom of the laptop.
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Locate and remove the screw that secures the CD-Rom Drive.
    • Locate and remove the screw that secures the CD-Rom Drive.
  4. Push the button on the lower right hand side of the CD-Rom drive component. The button should pop out. Then pull out the CD-Rom Drive from there.
    • Push the button on the lower right hand side of the CD-Rom drive component.
    • The button should pop out.
    • Then pull out the CD-Rom Drive from there.
Conclusão
2 outras pessoas concluíram este guia.
Brian Murphy
Membro desde: 13-04-2011
368 Reputação
4 Guias de autoria
equipe
Cal Poly, Team 18-22, Garner Spring 2011 Membro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membros
16 Guias de autoria
cuando estoy trabajando la unidad de cd expulsa el disco
Hector Alfonso - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 3,237
