Ir para o conteúdo principal
Dell Inspiron 7590 Battery Replacement
O que você precisa
  1. Dell Inspiron 7590 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 7590 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
    • Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
  2. Dell Inspiron 7590 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 7590 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 7590 Battery Replacement: passo 2, imagem 3 %32
    • Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
    • Separate the remainder of the paneling using an Opening Pick.
    • Avoid using a metal utensil when separating the remainder of the paneling to avoid paint chipping.
  3. Dell Inspiron 7590 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 7590 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 7590 Battery Replacement: passo 3, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the three screws securing the battery.
  4. Dell Inspiron 7590 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 7590 Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, disconnect the ribbon cable connecting the battery to the motherboard.
  5. Dell Inspiron 7590 Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 7590 Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery from the device.
Conclusão
Um comentário
Hello,
I noticed in your tear down there are two ram slots. I tried to find this information online, but was unable to. Are any of those ram slots an empty slot, to possibly upgrade?
Dave Szes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 19
Duração total: 1,525
