Introdução
This guide will walk you through how remove the hard drive from the systems board of your Dell Inspiron 7573 2-in-1 computer. This guide is useful for replacing a hard drive that may be defective or damaged. Complications such as file issues on your computer or data malfunctions may cause you to replace the hard drive.
O que você precisa
Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
