Ir para o conteúdo principal
Dell Inspiron 7573 2-in-1 Battery Replacement
O que você precisa
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 7573 2-in-1 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 7573 2-in-1 Battery Replacement: passo 2, imagem 3 %32
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: passo 3, imagem 1 %32
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 7573 2-in-1 Battery Replacement: passo 4, imagem 2 %32 Dell Inspiron 7573 2-in-1 Battery Replacement: passo 4, imagem 3 %32
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Conclusão
Uma outra pessoa concluiu este guia.
Kylie Freese
Membro desde: 09/27/21
405 Reputação
Autoria de 3 guias
Equipe
Casper College, Team 1-2, Lareau Fall 2021 Membro de Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 53
Duração total: 2,378
