Ir para o conteúdo principal
Dell Inspiron 7568 Trackpad Replacement Guide
O que você precisa
  1. Dell Inspiron 7568 Trackpad Replacement Guide, Battery: passo 1, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide, Battery: passo 1, imagem 2 %32
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Trackpad Replacement Guide: passo 2, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 2, imagem 2 %32
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: passo 3, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide, Track Pad: passo 3, imagem 2 %32
    • Unplug the speaker cable and remove the speakers
  4. Dell Inspiron 7568 Trackpad Replacement Guide: passo 4, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 4, imagem 2 %32
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) holding the touchpad bracket
    • Remove the touchpad bracket
  5. Dell Inspiron 7568 Trackpad Replacement Guide: passo 5, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 5, imagem 2 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 5, imagem 3 %32
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the touchpad ribbon cable free.
    • Use a nylon spudger to lift the ZIF connector tab. Gently pull the keyboard daughter board ribbon cable free.
  6. Dell Inspiron 7568 Trackpad Replacement Guide: passo 6, imagem 1 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 6, imagem 2 %32 Dell Inspiron 7568 Trackpad Replacement Guide: passo 6, imagem 3 %32
    • Remove the touchpad foil using a spudger or other ESD safe blunt-tip tool.
    • Unscrew & remove the three 2mm wafer screws holding the touchpad.
    • Remove the touchpad.
Conclusão
Yash Samant
Membro desde: 02/22/17
406 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G2, Lacy Spring 2017 Membro de USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 421
