Introdução
When removing or replacing the RAM of the Dell Inspiron 7568 it is important to make sure the laptop it is unplugged and completely turned off. User should also remember to be careful when unplugging and removing the battery. It is recommended that users keep different screw types separated to keep assembly easier. Make sure to uses a Phillips head #1 screw driver. Make sure to work in a static free area with static protection gloves.
O que você precisa
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
