Ir para o conteúdo principal
Dell Inspiron 7568 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 7568 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Motherboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Motherboard Replacement, RAM: passo 3, imagem 1 %32
    • Release the RAM by unhinging the connecting bars outward.
  4. Dell Inspiron 7568 Motherboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the RAM.
  5. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: passo 5, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: passo 5, imagem 2 %32
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  6. Dell Inspiron 7568 Motherboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  7. Dell Inspiron 7568 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Dell Inspiron 7568 Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove six 3mm Phillips #1 screws to fully remove the motherboard.
    • Disconnect the various connection points from the motherboard to the laptop.
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Elijah Basile
Membro desde: 11/06/19
358 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S1-G4, Stella Fall 2019 Membro de IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 292
