Ir para o conteúdo principal
Dell Inspiron 7486 Chromebook Battery Replacement
O que você precisa
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 2, imagem 2 %32
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 3, imagem 2 %32
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 4, imagem 2 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 4, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 5, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: passo 6, imagem 1 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 6, imagem 2 %32 Dell Inspiron 7486 Chromebook Battery Replacement: passo 6, imagem 3 %32
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
Conclusão
4 outras pessoas executaram este guia.
[deleted]
Membro desde: 09/19/20
265 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 16
Últimos 30 dias: 47
Duração total: 1,264
