Ir para o conteúdo principal
Dell Inspiron 700m Hinge Cover Replacement
O que você precisa
  1. Dell Inspiron 700m  Hinge Cover  Replacement, Removing battery: passo 1, imagem 1 %32
    • Remove the battery by sliding and holding the battery release latch.
    • Make sure your computer is turned off and unplugged.
  2. Dell Inspiron 700m  Hinge Cover  Replacement, Open display: passo 2, imagem 1 %32
    • Open the display 180 degrees.
  3. Dell Inspiron 700m  Hinge Cover  Replacement, Removing Display: passo 3, imagem 1 %32
    • Use a plastic flat screwdriver to slide the hinge caps away from the computer.
    • Detach the two display latches on the back of the computer.
    • Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
    • Carefully, lift the hinge cover from the main unit and remove it from the main unit.
Conclusão
irlanda
Membro desde: 11/30/17
12.231 Reputação
Autoria de 2 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.993 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 237
