Ir para o conteúdo principal
Dell Inspiron 7000 2 in 1 Battery Replacement
O que você precisa
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 2, imagem 1 %32
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, imagem 2 %32 Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, imagem 3 %32
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 4, imagem 1 %32
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 5, imagem 1 %32
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 7, imagem 1 %32
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 8, imagem 1 %32
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 9, imagem 1 %32
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 10, imagem 1 %32
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Linha de Chegada
3 outras pessoas executaram este guia.
Neelay Patel
Membro desde: 09/17/21
255 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 138
Duração total: 5,894
