Ir para o conteúdo principal
Dell Inspiron 6400 keyboard Replacement
O que você precisa
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, imagem 2 %32 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, imagem 3 %32
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement: passo 2, imagem 2 %32 Dell Inspiron 6400 keyboard Replacement: passo 2, imagem 3 %32
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement: passo 3, imagem 2 %32 Dell Inspiron 6400 keyboard Replacement: passo 3, imagem 3 %32
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement: passo 4, imagem 2 %32 Dell Inspiron 6400 keyboard Replacement: passo 4, imagem 3 %32
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement: passo 5, imagem 2 %32 Dell Inspiron 6400 keyboard Replacement: passo 5, imagem 3 %32
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: passo 6, imagem 1 %32 Dell Inspiron 6400 keyboard Replacement: passo 6, imagem 2 %32
    • Place the battery and lock it into place
Conclusão
kempc8
Membro desde: 11/22/13
899 Reputação
Autoria de 7 guias
Equipe
K and K Fixit Membro de K and K Fixit
Business
1 Membro
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 928
