Ir para o conteúdo principal
Dell Inspiron 600m Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: passo 3, imagem 1 %32
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Conclusão
7 outras pessoas executaram este guia.
Todd
Membro desde: 04/05/11
146 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-40, Forte Spring 2011 Membro de Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
Membros da 5
Autoria de 8 guias
2 comentários
What size is the hard drive, you know, to buy a new one?
Ethan White - Responder
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Duração total: 17,208
