Ir para o conteúdo principal
Dell Inspiron 6000 Screen Replacement
O que você precisa
  1. Dell Inspiron 6000 Screen Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Screen Replacement: passo 2, imagem 1 %32
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 6000 Screen Replacement, Keyboard: passo 3, imagem 3 %32
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Screen Replacement: passo 4, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 4, imagem 2 %32
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Screen Replacement: passo 5, imagem 1 %32
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Screen Replacement: passo 6, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 6, imagem 2 %32 Dell Inspiron 6000 Screen Replacement: passo 6, imagem 3 %32
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Screen Replacement, Screen: passo 7, imagem 1 %32
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
  8. Dell Inspiron 6000 Screen Replacement: passo 8, imagem 1 %32
    • Pull and disconnect the blue tab.
  9. Dell Inspiron 6000 Screen Replacement: passo 9, imagem 1 %32
    • Disconnect the black and white wires.
  10. Dell Inspiron 6000 Screen Replacement: passo 10, imagem 1 %32
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
  11. Dell Inspiron 6000 Screen Replacement: passo 11, imagem 1 %32
    • Separate the top panel of the laptop from the bottom panel.
  12. Dell Inspiron 6000 Screen Replacement: passo 12, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 12, imagem 2 %32
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
  13. Dell Inspiron 6000 Screen Replacement: passo 13, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 13, imagem 2 %32
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
  14. Dell Inspiron 6000 Screen Replacement: passo 14, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 14, imagem 2 %32
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
  15. Dell Inspiron 6000 Screen Replacement: passo 15, imagem 1 %32 Dell Inspiron 6000 Screen Replacement: passo 15, imagem 2 %32
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
Conclusão
3 outras pessoas executaram este guia.
Jacob DeWar
Membro desde: 09/23/14
533 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membro de USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 2,701
