Ir para o conteúdo principal
Dell Inspiron 6000 DVD/CD Drive Replacement
O que você precisa
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: passo 2, imagem 1 %32
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: passo 3, imagem 1 %32
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: passo 4, imagem 1 %32
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: passo 5, imagem 1 %32
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: passo 6, imagem 1 %32
    • Using your hand, pull the disk drive out of the laptop.
Conclusão
Kenneth Odum
Membro desde: 09/23/14
545 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membro de USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 1,880
