Introdução
This guide will show you how to replace the touchpad on the Dell Inspiron 5758.
O que você precisa
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
