Introdução
In this guide, we will show you how to remove and replace the Memory Modules.
O que você precisa
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Quase terminado!
Linha de Chegada
