Pular para o conteúdo principal
Introdução
You will need a good knowledge of computers to know how to do this.
  1. Remove the side panel, and and and screws that may be holding it in place.
    • Remove the side panel, and and and screws that may be holding it in place.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  3. Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Take the old GPU out and put the new GPU in its place.
    • Make sure that you have correctly grounded yourself and that you are using proper tools to reduce the risk of ESD and component destruction. Also make sure that the graphics card that you are using has enough voltage to be powered by your current power supply.
Conclusão
To reassemble your device, reattach any cables and screws that were disconnected and put the cover back on.
Uma outra pessoa concluiu este guia.
bacon
Membro desde: 26-04-2016
226 reputação
Autoria de 1 guia
En français on ne dit pas “Processeur graphique” mais “Carte Graphique” car on achète et on change toute la carte graphique.
Hyperion - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 26
Todo: 784
