Introdução
Replacing the RAM is simple, push down a snap to unlock it, pull it out then push the new one into place.
O que você precisa
Locate and unscrew the two large screws at the back of the computer. Once the screws are removed, the panel on the right side will slide towards the back, and release itself. Lift the panel off the computer to reveal the internals.
The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
Pull up on the RAM chip to remove it.
Uma outra pessoa concluiu este guia.
