Ir para o conteúdo principal
Dell Inspiron 530 DCMF RAM Replacement
O que você precisa
  1. Dell Inspiron 530 DCMF RAM Replacement, RAM: passo 1, imagem 1 %32 Dell Inspiron 530 DCMF RAM Replacement, RAM: passo 1, imagem 2 %32
    • Locate and unscrew the two large screws at the back of the computer. Once the screws are removed, the panel on the right side will slide towards the back, and release itself. Lift the panel off the computer to reveal the internals.
  2. Dell Inspiron 530 DCMF RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron 530 DCMF RAM Replacement: passo 2, imagem 2 %32 Dell Inspiron 530 DCMF RAM Replacement: passo 2, imagem 3 %32
    • The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
    • On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
    • Pull up on the RAM chip to remove it.
    • Do not touch the gold edge of the chip. The oils on your hands can damage it.
  3. Dell Inspiron 530 DCMF RAM Replacement: passo 3, imagem 1 %32 Dell Inspiron 530 DCMF RAM Replacement: passo 3, imagem 2 %32
    • When inserting the new chip, find the open slot you just took one out of, and then line up the pins on the stick with the holes in the slot, then push down firmly.
    • Once the RAM is in, make sure to push up the white tabs on each side to lock it in place.
Conclusão
Uma outra pessoa concluiu este guia.
Drew Cunningham
Membro desde: 03/25/15
656 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-1, Kish Spring 2015 Membro de UMass Dartmouth, Team 5-1, Kish Spring 2015
UMASSD-KISH-S15S5G1
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 973
