Ir para o conteúdo principal
Dell Inspiron 530 CD/DVD Drive Replacement
O que você precisa
  1. Dell Inspiron 530 CD/DVD Drive Replacement, Side Panel: passo 1, imagem 1 %32
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Dell Inspiron 530 CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • Slide the side panel towards the back and remove.
  3. Dell Inspiron 530 CD/DVD Drive Replacement, CD/DVD Drive: passo 3, imagem 1 %32
    • Locate the CD/DVD drive in the upper-front corner of the case.
  4. Dell Inspiron 530 CD/DVD Drive Replacement: passo 4, imagem 1 %32
    • Locate and remove the two cables attached to the CD/DVD drive.
  5. Dell Inspiron 530 CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Locate and remove the two Phillips #0 7.8 mm screws.
  6. Dell Inspiron 530 CD/DVD Drive Replacement: passo 6, imagem 1 %32
    • Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Gently lift the three tabs to pull off the faceplate.
  7. Dell Inspiron 530 CD/DVD Drive Replacement: passo 7, imagem 1 %32
    • Pull the faceplate forward and out.
  8. Dell Inspiron 530 CD/DVD Drive Replacement: passo 8, imagem 1 %32
    • Completely remove the faceplate.
    • Remove the CD/DVD drive by pulling it forward towards the front.
Conclusão
17 outras pessoas executaram este guia.
Doug Howe
Membro desde: 10/23/11
2.161 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-8, Regan Fall 2011 Membro de Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
Membros da 4
Autoria de 18 guias
Um comentário
add the problems may happen and ther solution
mersen getu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 17,421
