Ir para o conteúdo principal
Dell Inspiron 530 Replacement of GPU
O que você precisa
  1. Dell Inspiron 530 Replacement of GPU, GPU: passo 1, imagem 1 %32
    • Remove the side panel, and and and screws that may be holding it in place.
  2. Dell Inspiron 530 Replacement of GPU: passo 2, imagem 1 %32
    • Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Take the old GPU out and put the new GPU in its place.
    • Make sure that you have correctly grounded yourself and that you are using proper tools to reduce the risk of ESD and component destruction. Also make sure that the graphics card that you are using has enough voltage to be powered by your current power supply.
Conclusão
To reassemble your device, reattach any cables and screws that were disconnected and put the cover back on.
3 outras pessoas executaram este guia.
bacon
Membro desde: 04/26/16
277 Reputação
Autoria de 1 guia
Um comentário
En français on ne dit pas “Processeur graphique” mais “Carte Graphique” car on achète et on change toute la carte graphique.
Hyperion - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 1,822
