Ir para o conteúdo principal
Dell Inspiron 5100 PP07L Memory Replacement
O que você precisa
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: passo 1, imagem 1 %32
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: passo 2, imagem 1 %32
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, imagem 1 %32 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, imagem 2 %32 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, imagem 3 %32
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Conclusão
May Chauvin
Membro desde: 04/14/11
201 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-34, Maness Spring 2011 Membro de Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 4,500
