Peças
Não são necessárias peças.
  1. Flip to the back side of the laptop
    • Flip to the back side of the laptop
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Loosen one screw.
    • Loosen one screw.
    • This screw is attached to the panel and cannot be removed.
  4. Spread out pins on the opposite sides. The chip will spring up at an angle. Place new chip in at a 30 degree angle. Push inward until pins can't be seen.
    • Spread out pins on the opposite sides. The chip will spring up at an angle.
    • Place new chip in at a 30 degree angle.
    • Push inward until pins can't be seen.
    • Push RAM down, so it lays flat.
    • Improperly replacing the RAM will cause it to short-circuit.
Conclusão
2 outras pessoas concluíram este guia.
May Chauvin
186 reputação
6 Guides authored
Equipe
Cal Poly, Team 12-34, Maness Spring 2011 Membro de Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Todo: 3,775
