Ir para o conteúdo principal
Dell Inspiron 3552 Hard Drive Replacement part 2
O que você precisa
  1. Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, imagem 1 %32 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, imagem 2 %32 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: passo 1, imagem 3 %32
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly
    • Open the latch and disconnect the hard-drive cable from the system board
    • Lift the hard-drive assembly off the palm-rest assembly
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift it off the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive
    • Connect the interposer to the hard-drive assembly
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly
    • Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Slide the hard-drive cable into the system-board connector and close the latch to secure the cable.
Conclusão
Jordon Dozier
Membro desde: 02/10/21
1.663 Reputação
Autoria de 12 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 374
